Activity Forums AJA Video Systems IoHD odd 9 frame slide
  • Gary Adcock
    April 29, 2008 at 1:10 pm
    [Lawrence Shea] “f time permits this week, I’ll call them and give it another go although I suspect that this problem is perhaps due to a software bug. Puzzling!”
    LS…
    Are you sure you went thru the IoUpater process fully? It is Vital that you cycle the power on your computer and the IoHD after installing the drivers, it is the only way the Firmware is properly updated in the unit itself….
    Uninstall using the utility for that in the Applications > AJA folder –then reinstall following the written process by cycling the power on both the IoHD and your computer.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
    Inside look at the IoHD
  • Lawrence Shea
    April 29, 2008 at 4:58 pm
    Thanks Gary
    Just to be absolutely sure that my install was correct, I just reinstalled the software, following directions to a T. Unfortunately, same symptoms.
Page 2 of 2
