Activity Forums AJA Video Systems io HD noob
  • Scott Phillips
    June 15, 2011 at 10:04 pm
    I changed the master gain in clip settings to 1. Tried again and no change.
    Here’s my Behringer FWIW:
  • Jeremy Garchow
    June 15, 2011 at 10:44 pm
    I dont see any video cables?
  • Scott Phillips
    June 16, 2011 at 1:15 pm
    The video runs from the camera into the io HD via component.
  • Jeremy Garchow
    June 16, 2011 at 1:23 pm
    And you have that plugged in and camera on when doing these tests right?
    You can’t capture without some video going to the ioHD.
    One more screen cap for me.
    You need to arrange your windows so that I can see both the control panel and Fcp log and cap window.
    With FCP selected and log and capture open, take a screen cap. Fcp must be selected and control panel visible. You might have to close the Fcp canvas/viewer.
  • Scott Phillips
    June 16, 2011 at 1:56 pm
    yep–I’m capturing audio and video.
    Here’s the control panel:
  • Jeremy Garchow
    June 16, 2011 at 2:25 pm
    Thanks so much. And you turn up the master out of the mixer, and nothing?
    No meters on the front of the io either?
    If so, it’s time to pick up the phone and call AJA. It appears you have everything setup correctly from what I can see from here.
    Sorry I couldn’t help.
  • Scott Phillips
    June 16, 2011 at 2:42 pm
    thanks for all your assistance.
    Yes, I haven’t maxed everything, but gain, level and mix is all just shy of max and it is registering on the io HD meters, but not very high. Just like FCP–it is moving, but not anywhere near where I would expect.
    Hopefully the AJA people will have some ideas.
    thanks again.
Page 5 of 5
