Activity Forums AJA Video Systems Intermittent handle problems
  • Scott Davis
    November 11, 2008 at 12:00 am
    Jeremy, I just got our HVR-M15U and hooked it up via FW. Capturing perfectly. On capture with the HVR-1500 I kept getting the warning that it was reading NDF so I assumed that the tapes were shot NDF and set the TC as NDF. With the M15 I set it at DF and all is fine. Do you know how to get DF out of the 1500? I am looking through the user manual and don’t see anything.
    Scott Davis
    View Scott Davis's profile on LinkedIn
  • Jeremy Garchow
    November 11, 2008 at 3:26 am
    I have not worked with that deck before, but doesn’t the 1500 have rs422? If you re using 9 pin serial control df/ndf should be detected automatically.
  • Scott Davis
    November 11, 2008 at 7:40 pm
    Ok, after banging my head against this all morning. I confirmed with the DP that the field tapes are absolutley NDF. Both the 1500 and the M15 are detecting this correctly. The 1500 is sending NDF TC out. The M15 I cant tell.
    -In the AJA control panel it says that the incoming video signal is 1080i29.97.
    -I am capturing into DV. Is DV a DF TC codec only?
    Thanks, for you help. I feel like a dog chasing his own tail right now.
    Scott Davis
  • Jeremy Garchow
    November 17, 2008 at 4:38 pm
    [Scott Davis] “-I am capturing into DV. Is DV a DF TC codec only? “
    No, it’s not but it usually defaults to DF. There’s a firewire NDF device control preset.
    Sorry it’s taken so long to get back to you, I just returned from a job.
  • Scott Davis
    November 17, 2008 at 6:23 pm
    Jeremy, thanks for your help. After numerous test I’ve come to the conclusion that the problem lies with some sort of incompatibility between FCP/Kona/HVR-1500. Our M15u with FW control work great. Go figure. I’ve sent the 1500 back (we were renting) and got an M25 instead.
    Scott Davis
  • Jeremy Garchow
    November 17, 2008 at 6:34 pm
    You have let AJA know I take it?
Page 2 of 2
