Activity › Forums › Avid Media Composer › interlacing? sudden unexplained problem with rendering and exporting
Ronald Czarnecki replied 15 years, 10 months ago 5 Members · 12 Replies
Gaetano Lucido
February 24, 2010 at 6:21 pmHi,
I had the same problem and since I found a solution, which may not be the best, but once you master it, it works perfectly.
I’m talking about the rendering of transitions.
I got the same problem once the file was rendered: green and withe lines each time there was a transition.
I learned to work with transparency, I put transparency at the end of one clip and another at the beginning of following clip.
The firs fading out and the second fading in. The two clips must over lap. In that way you create you own transitions.
I didn’t read the all topic cause it was too long, but if at the end you found a solution better than mine, I’ll be glad to know it and see where the problem comes from.
Thank you
Gaetano Lucido -
Ronald Czarnecki
November 11, 2010 at 2:24 pmThe answer in found to the Green transition dissolves was changing the Time Line Properties, only Non interlace worked.
If you used uncompressed for render you get large render files so you have to pick render/fuse Mpeg 2. Top Field First and Bottom Field First were not working for me.
