Installing a codec in Virtual Dub
John Rofrano replied 16 years, 11 months ago 2 Members · 25 Replies
Jim Murphy
October 17, 2009 at 1:52 amJohn, I have it working, but since I cannot find the codec in the list (I must be using 64 bit), I am using it uncompressed. It does do a good job. I just wish it were a little more user friendly. But…the price is right 🙂 If you have other info on how I can use/find the 32 bit version and use a codec, that would be great. If not I can probably get away with using uncompressed. I typically need to steady very small clips. Thanks for all your help. Jim
Vegas Pro 8 DVDA 5 Excalibur
Dell Quad Core 2.67 GHz
Jim Murphy
October 17, 2009 at 2:37 amMurphy’s law is taking over. I thought I had it, but the AVI I produced had a smaller video size. My clips in Vegas are 1440 x 1080. So in pass 2 of Deshaker what should I set Destination Pixel Aspect to and what should I set the Destination Video Size to? I have tried a bunch of experiments, but not getting the results I need. Thanks, Jim
John Rofrano
October 17, 2009 at 11:58 amThe Pixel Aspect Ratio of HDV 1440×1080 is 1.3333. In DeShaker you should be able to use the option Save destination properties as source. Otherwise, select HDV 1440×1080 (1.333) as the destination pixel aspect in DeShaker and adjust the destination video size to 1440×1080.
What I would do is download the Lagarith codec. This has both a 32-bit and 64-bit version. Install them both. In Vegas, make a Windows AVI template that uses Lagarith at 1920×1080. In VirtualDub output to 1920×1080. This eliminates all of the headaches with the pixel aspect ratio of 1440×1080 PAR 1.3333. If you do the math, 1440 * 1.3333 = ~1920 so there is minimal loss in information doing it this way. I do all of my external compositing at 1920×1080 to avoid these kinds of problems with programs that don’t interpret PAR correctly.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Jim Murphy
October 17, 2009 at 2:38 pmI realized from your last email that I did not have the latest version of Deshaker, so I have installed the latest version. I installed the Lagarith codec. In Vegas I made an AVI template using the Lagarith codec at 1920 x 1080. So far, so good. However, when I import the AVI into Virtual Dub it takes up the entire screen and I no longer see the right side output screen. Also, when I try to run Pass 2 I get the error message “Unable to open file….for write because it is being used by another process.” I don’t understand this because Virtual Dub is the only program I have open at that time. Still wondering what I am doing wrong. Thanks, Jim
John Rofrano
October 17, 2009 at 6:01 pm> However, when I import the AVI into Virtual Dub it takes up the entire screen and I no longer see the right side output screen.
Right-click on the frame and select a zoom that’s less than 100% for both sides. (maybe 50%)
Make sure that you are not saving over the same file that you are reading from. (i.e., you must render to a different filename)
~jr
