Activity › Forums › Lighting Design › Inexpensive LED lights
  • Kenny Kinds
    March 31, 2011 at 8:41 pm
    wow,
    thanks guys for your input. Will look into all of your suggestions.
    kenny
  • David Speace
    April 2, 2011 at 4:15 pm
    Kenny,
    Here’s a light that I designed and use. I sell it on ebay.
    https://cgi.ebay.com/Grip-LED-led-light-DZP-Video-/290551364698?pt=Camcorders_Professional_Video_Cameras&hash=item43a635fc5a
    Dave Speace
    Producer/Director/DP
    DZP Video
    Windows 7, 64 Bit, i7 8 Core, 16Gb Ram, GeForce 4800
  • Dennis Size
    April 2, 2011 at 5:45 pm
    Very nice…and at only $250 !!???
    What are the photometrics?
    DS
  • David Speace
    April 3, 2011 at 10:24 pm
    Dennis,
    Here are the specs on this light…if you are interested I will send you one to try out! Also, I’ve attached my lighting plot for tomorrow’s shoot… “Best of Class” for 6ABC.
    Bulb types – 1 watt led x 36 w/ collimated lenses (can remove-not recommended)
    Life – 50,000 hrs
    Body – Aluminum
    Color temp – 5500K
    Angle – 30o + 50o mixed
    Output – 3000 lumens
    Voltage – 120-240 VAC or 24V DC
    Usage – 40W
    Size – 11” x 11” x 1 5/8”
    Mount – Standard 3 ½” grip pin
    Diffusion – Duralens translucent white & clear
    Dave Speace
    DZP Video
  • David Speace
    April 3, 2011 at 10:32 pm
    Dennis,
    Life – 50,000 hrs
    Body – Aluminum
    Color temp – 5500K
    Usage – 40W
    Mount – Standard 3 ½” grip head
    Here’s the lighting plot:
    1830_bclassltplot.pdf.zip
    Dave Speace
    DZP Video
  • David Speace
    May 4, 2011 at 4:20 pm
    I thought that I would add a little more to this thread… the setup I did for 6ABC’s “Best of Class” was totally different because I was in a different room! So here’s a couple of pictures of the setup…
    and here is the plot I originally did…
    Also… the led light that I am using… Grip-LED, a light that I build myself… it turns out that at this posting the panel that I am using is not available… is “out of stock” from the supplier. Not sure that I will be able to get more! It seems that other “established” lighting companies are using this panel!
    Dave Speace
    DZP Video
  • David Wong
    July 5, 2011 at 6:18 am
    More and more professional led lights tech information on the topledsupplier website.
    Professional LED lights website : https://www.topledsupplier.com
    A new way to lights up your life for led grow lights.
    https://www.ledlightsliving.com/led-grow-lights-c-105.htm
Page 2 of 2
