  • Steven Gonzales
    August 18, 2005 at 5:42 pm
    Slightly OT, but does the conform process also work for audio in the same quicktime file (slowing it down slightly, for example, when conforming from 24 to 23.98)?
    Does it do this by changing the sample rate?
    Thanks, I’ve been curious about this process.
  • Graeme Nattress
    August 18, 2005 at 5:44 pm
    Yes, yes and yes.
    G
    – http://www.nattress.com – Film Effects and Standards Conversion for FCP
  • Tony Mazzarella
    August 18, 2005 at 7:16 pm
    Tony Mazzarella
    Mazzarella Bros. Productions, Inc
    Bristol, CT USA
  • Tony Mazzarella
    August 18, 2005 at 7:18 pm
    The conform option worked great! But now my audio is off, a forseeable problem. Any quick fixes or features for this one, or do I just re-sync audio manually?
    Tony Mazzarella
    Bristol, CT USA
  • Graeme Nattress
    August 18, 2005 at 7:20 pm
    The audio should get converted along with the video, and remain in sync, or are you trying to use the pre-conform audio??
    Graeme
  • Tony Mazzarella
    August 18, 2005 at 7:31 pm
    No we this is the conformed audio. We relinked the sequence with all the newly conformed media. Wierd?
    Tony Mazzarella
    Bristol, CT USA
  • Graeme Nattress
    August 18, 2005 at 8:00 pm
    Did you change the sequence itself to 23.98fps?
    Graeme
  • Tony
    August 21, 2005 at 5:46 pm
    Tony,
    Your case is a good example of why it is essential to understanding the post production workflow long before you start shooting.
    It is not safe to rush over and skip critical technical information and knowledge just so you can avoid all the techno mumbo jumbo.
    Expecting to output 24P to standard def was a major oversight since there is no current 24P standard def vtr in existence.
    Tony Salgado
  • Tony Mazzarella
    August 22, 2005 at 12:12 pm
    You’re absolutely right. Myself and my production team learned a frustrating lesson this past week. Luckily we were able get working thanks to everyone here @ Creative Cow!
    Cheers.
    Tony Mazzarella
    Bristol, CT USA
Page 2 of 2
