Activity › Forums › Apple Final Cut Pro Legacy › IMX 50 .MXF delivery help
  • Jeremy Garchow
    March 4, 2010 at 11:56 pm
    You will want to keep the 720×480 frame size and the dv ratio. Then in padding
    choose the 16:9 preset. Once you get that letterbox file, then go into Sony software and export the MXF. IT should add the extra padding for you. Make sense?
  • Brian Whitton
    March 5, 2010 at 4:03 pm
    Thank you!
    I set the compressor settings as you said, exporting using the IMX 50mb/s preset in XDCAM transfer, and when the IMX opens in XDCAM, the dimensions still say 720×480. Is the 512 implied?
    How tired are you of my nonsense by now?
  • Jeremy Garchow
    March 5, 2010 at 4:07 pm
    [Brian Whitton] “How tired are you of my nonsense by now?”
    🙂 It’s all good, Brian. No worries.
    What if you open the file in VLC?
  • Brian Whitton
    March 18, 2010 at 3:50 pm
    Jeremy,
    Sorry for the late reply. SXSW came out of nowhere!
    Anyway, it looks perfect in VLC. 720×512 is the listed frame size! Amazing.
    Thanks for all the help, and I’m sure I’ll be back.
    Case CLOSED.
  • Alexandre Borges
    May 21, 2010 at 6:40 pm
    Hey all,
    I’m having a similar problem. I have to delivery 2 videos with this 2 specs:
    1
    Video: MPEG 16Mbps, LONG GOP, 4:2:2, 720×486, 29.97fps
    Audio: aiff, 16bps : VBI Type: SMPTE 436M on line 12
    DID=45H; SDID:01H
    Container: .MXF(OP1A Internal)
    2
    Video: XDCAM 50, 1920×1080; 29.97fps
    Audio: aiff, 16bps; VANC Type SMPTE 436M on line 10
    DID=45H; SDID=01H
    But using Sony XDCAM Transfer I didn’t found this settings, or even a custom which I can change. There are some way to increase the settings of export in Sony XDCAM Transfer or I’ll have to use other way to export this .mxf files? Which way?
    Alex
  • James Kommoss
    March 11, 2011 at 11:45 am
    Hi Brian,
    I’m just wondering how you got on with this in the end? I have a similar delivery to the same station, so far I’ve tested it thus:
    Sequence setting is IMX 50, with audio output at 4, and XDCAM transfer. VLC sees the extra padding correctly.
    Now I’m wondering about the XML file that I have to provide. Is this just an ordinary FCP xml file, of the sequence in which the video sits?
    Many thanks for any help you can provide!
    Best regards,
    James
  • Jeremy Garchow
    March 11, 2011 at 4:57 pm
    [James Kommoss] “Now I’m wondering about the XML file that I have to provide. Is this just an ordinary FCP xml file, of the sequence in which the video sits?”
    What did the specs say to deliver?
  • Omer Ozcan
    April 4, 2013 at 7:27 pm
    hello,
    i need to deliver quite similar video for a tv channel.
    they ask for SD IMX 50 with 24 bit audio.
    i did well except 24 bit audio. i have 24 bit aiff tracks. my sequence has 24 bit settings. however when i go for xdcam export, if i choose IMX 50, it only allows 16 bit audio. i cant change it to 24 bit.
    what’s wrong with my steps?
    thanks in advance.
Page 3 of 3
