Activity › Forums › Apple Motion › Importing Vector Images
David Jolosky
May 12, 2011 at 12:13 aminstead of importing .ai, save as PDF and import
then change “fixed aspect”
d
david jolosky, visual communications || design || construct || interact
Zack Olson
May 12, 2011 at 1:53 amThanks for the quick reply.
Where can I find and change “fixed aspect” as you have suggested?
Zack Olson
May 12, 2011 at 1:56 amI answered my own question. The issue is, i was zooming in the view and not changing the scale in the properties tab. I was fine with infinite resolution, but when I zoomed in, it was getting jagged.
Rookie mistake! Still trying to wrap my arms around the Motion interface.
Thanks again for all your help!
Stephen Smith
May 12, 2011 at 3:15 pmTo change the “Fixed Aspect Ratio” do the following: Open up the Project Pane. Click on the Media tab. Select the AI file. Click on the Inspector tab in the Inspector. Select the Media tab if it is not already selected. Un check the Fixed Resolution check box. Jaggy edges become smooth.
Also set your resolution to best.
Stephen Smith
Utah Video ProductionsCheck out my Motion Training DVD
Check out my Motion Tutorials
