Activity › Forums › Panasonic Cameras › Importing p2 material from firewire drive.
Todd Mcmullen replied 20 years, 6 months ago 5 Members · 12 Replies
Jeremy Garchow
March 9, 2006 at 9:59 pm[Shane Ross] “Just don’t re-name the CONTENTS folders. Make new folders and drag CONTENTS and LASTCLIP.TXT into that”
Exactly, it’s like you should put everything in a folder by a “reel name” or in this case every card download. So if you shot four cards full today, make a folder called “Card 1” or whatever and then dump the contents and text file into that. then make a folder called “card 2” and dump that card’s contents into that folder. It’s what I do and it works just fine. Maybe this will change if FCP will support native MXF instead of the quicktime wrapped files. Nabbage will tell us.
Todd Mcmullen
March 9, 2006 at 10:52 pmYes, In my case not putting the .txt file in was a mistake, but, you can still import into fcp, you just have to do it 1 contents folder at a time.
Thanks for the replies.
Todd McMullen
Flip Flop Films
Austin
Cinematography Forum Leader
