Activity Forums Apple Final Cut Pro Legacy importing .mts files into FCP 7
  • Christopher Targia
    May 29, 2012 at 2:05 pm
    So what do you do if you don’t have the structure, someone just sent me a bunch of .MTS files and expected me to be able to open them. I can only view them with VLC, which doesn’t help me use them in FCP.
    MacPro Octo Core Intel Xenon 2.8Ghz 10GB DDR2 Ram
    FCP 7.0.3
    -I highly recommend el Gato Turbo264HD-
  • Shane Ross
    May 29, 2012 at 2:09 pm
    Then look at Clipwrap 2 by divergentmedia.com
    Shane
    Little Frog Post
    May 30, 2012 at 1:21 pm
    Is there a way to do it for free?
    FCP 7.0.3
  • Shane Ross
    May 30, 2012 at 1:37 pm
    Not that I know of. MPEG Streamclip doesn’t work with this format.
    Shane
    Little Frog Post
    May 30, 2012 at 6:04 pm
    Okay thanks, I asked these people to please resend me the files including all the folders and file structure so I could read it. They then sent me the all the rest of the files on the camera, ie .CPI, .MPL, etc. and no folders… ::facepalm:: I may end up needing to purchase this.
    FCP 7.0.3
  • Bobby Hall
    July 13, 2013 at 4:39 am
    Shane,
    Regarding your tutorial video, do you only need to backup all the folders and files on a memory card if you want to log and transfer the MTS files in FCP?
    I’m able to import MTS files in Pavtube iMedia Converter and convert them to ProRes. With this method, I have no need for all the other folders and files on the card, right?
  • David Eaks
    July 13, 2013 at 5:00 pm
    Hi Bobby,
    I don’t really see any advantage to copying only the mts files, yet there are many potential downfalls to doing so. Just copy the entire card, with all of its folder structure, every time. Making this your standard procedure will undoubtedly save you some skin sooner or later.
  • Shane Ross
    July 13, 2013 at 6:52 pm
    What David said. There is no advantage to only grabbing the .mts files, the full card structure doesn’t take up that much more space. And some of the current NLEs need the full card structure in order to work. Who knows when PAVTUBE will no longer be made, or when an NLE that does work with those files natively no longer is made.
    Do what you want, but my advice is to back up everything, because you don’t really know what files are important, and what files aren’t.
    Shane
    Little Frog Post
  • Bobby Hall
    July 14, 2013 at 6:29 am
    Good advice Shane. Thanks. I did what you suggested. 🙂
  • Bobby Hall
    July 14, 2013 at 6:56 am
    I made two long recordings on my camera and when I look at the files on my card, it lists several mts files, meaning it broke them up into chunks. What’s the best way to merge them together so they play seamlessly? Is ClipWrap the best for that?
Page 2 of 3
