Activity › Forums › AJA Video Systems › importing dvcpro hd from m10u to lhe audio/video settings?
Jeremy Garchow replied 19 years, 8 months ago 4 Members · 12 Replies
Walter Biscardi
December 16, 2006 at 11:24 pm[JeremyG] “What you need to do is select the 1080i DVCPRo HD capture preset then go into the log and capture, window and change your capture device to HDV firewire.”
This doesn’t work with FCP 5.1.2 and not sure if it works with any FCP version. If FCP sees the HDV signal via Firewire, it says that all settings must be HDV to capture. The only way to control the deck is to ensure that the Firewire is set to downconvert to DV and then use DV for Deck control.
Walter Biscardi, Jr.
HD Editorial & Animation for Food Network’s “Good Eats”
HD Editorial for “Assignment Earth”“I reject your reality and substitute my own!” – Adam Savage, Mythbusters
