Activity Forums Avid Media Composer Importing AVI’s with alpha channel PAL
  • Mcqueen
    July 30, 2007 at 8:35 pm
    I am working in PAL and cannot get it to import files created at a res. of 1024 x 576 uncompressed AVI’s with alpha channel. This method worked well with Xpress Pro 4.6 but not with 5.7
  • Erik Pontius
    July 31, 2007 at 6:37 am
    Ok… that’s standard def widescreen PAL using square pixels. However, on import you’ll want to choose the 601/709 non-square pixel import option…which I think you discovered.
    You HDV comps should be 1920×1080 square pixels.
    16×9 Widescreen PAL SD 1024×576 square pixels.
    4×3 PAL SD 768×576 square pixels.
    Erik
  • Mcqueen
    August 1, 2007 at 5:22 pm
    Must be something to do with the alpha channel as I can import 1048 x 576 uncompressed AVI’s and QT’s at 24 bits.
    The 32 bit anims still work in premiere as I installed an old version just to check.
Page 2 of 2
