Mark Braden
September 8, 2010 at 11:27 amI have run into this. I was able to work around it by changing the destination folder that the files are sent to. I think it has something to do with the automatic file naming. It would look like it was going to import but them stop. When I started giving each import it’s own folder it worked fine. I noticed that the separate folders had the same file names in them. Windows 7 automatically renamed them when I brought them into the same folder after I was finished. 🙂
Antoine Guy
September 8, 2010 at 2:32 pmThanks Mark, but I’m using Vista. But I’ll try your method. Could you please detail what I should do exactly?
