Activity › Forums › Square Box CatDV › Image Sequences?
  • David Jahns
    April 21, 2011 at 6:34 pm
    Bryson – I’ve verified the same behavior on another machine, (both Macs), and it sounds like Matt has as well.
    Matt – it doesn’t crash the system, so how do I find the CatDV log? (I’ve only seen that come up after a crash.)
    David Jahns
    Joint Editorial
    Portland, OR
  • Matthew Stamos
    April 21, 2011 at 7:02 pm
    Applications/utilities/console
  • David Jahns
    April 21, 2011 at 7:32 pm
    OK – i re-created exactly the problem. Imported one sequence, build thumbnails, save, quite, restart.
    Here’s the Error Log:
    (Just tried the attachment button above – Not sure what happened to it) – here’s a cut/paste version, or I could email it to matthew if that would be better.
    4/21/11 12:20:02 PM [0x0-0xb63b63].uk.co.squarebox.CatDVPro[21428] Load CatDV library
    4/21/11 12:20:02 PM [0x0-0xb63b63].uk.co.squarebox.CatDVPro[21428] Attempting to load main class squarebox.catdv.ProLauncher
    4/21/11 12:20:02 PM [0x0-0xb63b63].uk.co.squarebox.CatDVPro[21428] args=0
    4/21/11 12:20:02 PM [0x0-0xb63b63].uk.co.squarebox.CatDVPro[21428] tzOffset = -28800
    4/21/11 12:20:02 PM java[281] *** __NSAutoreleaseNoPool(): Object 0x10010eda0 of class NSConcreteMapTableValueEnumerator autoreleased with no pool in place – just leaking
    4/21/11 12:20:02 PM [0x0-0xb63b63].uk.co.squarebox.CatDVPro[21428] Starting up CatDV…
    4/21/11 12:20:07 PM [0x0-0xb63b63].uk.co.squarebox.CatDVPro[21428] Thu Apr 21 12:20:07 joint-gamecap.wk.com CatDV[21428] : kCGErrorIllegalArgument: _CGSFindSharedWindow: WID -1
    4/21/11 12:20:07 PM [0x0-0xb63b63].uk.co.squarebox.CatDVPro[21428] Thu Apr 21 12:20:07 joint-gamecap.wk.com CatDV[21428] : kCGErrorFailure: Set a breakpoint @ CGErrorBreakpoint() to catch errors as they are logged.
    4/21/11 12:20:07 PM [0x0-0xb63b63].uk.co.squarebox.CatDVPro[21428] Thu Apr 21 12:20:07 joint-gamecap.wk.com CatDV[21428] : kCGErrorIllegalArgument: CGSGetWindowDepth
    4/21/11 12:21:56 PM [0x0-0xb65b65].uk.co.squarebox.CatDVPro[21463] Load CatDV library
    4/21/11 12:21:56 PM [0x0-0xb65b65].uk.co.squarebox.CatDVPro[21463] Attempting to load main class squarebox.catdv.ProLauncher
    4/21/11 12:21:56 PM [0x0-0xb65b65].uk.co.squarebox.CatDVPro[21463] args=0
    4/21/11 12:21:56 PM [0x0-0xb65b65].uk.co.squarebox.CatDVPro[21463] tzOffset = -28800
    4/21/11 12:21:56 PM java[281] *** __NSAutoreleaseNoPool(): Object 0x10012d6d0 of class NSConcreteMapTableValueEnumerator autoreleased with no pool in place – just leaking
    4/21/11 12:21:56 PM [0x0-0xb65b65].uk.co.squarebox.CatDVPro[21463] Starting up CatDV…
    4/21/11 12:21:56 PM [0x0-0xb65b65].uk.co.squarebox.CatDVPro[21463] Toolkit squarebox.toolkit.common.MacIntelToolkit@1ed1b0b
    4/21/11 12:22:06 PM [0x0-0xb65b65].uk.co.squarebox.CatDVPro[21463] Thu Apr 21 12:22:06 joint-gamecap.wk.com CatDV[21463] : kCGErrorIllegalArgument: _CGSFindSharedWindow: WID -1
    4/21/11 12:22:06 PM [0x0-0xb65b65].uk.co.squarebox.CatDVPro[21463] Thu Apr 21 12:22:06 joint-gamecap.wk.com CatDV[21463] : kCGErrorFailure: Set a breakpoint @ CGErrorBreakpoint() to catch errors as they are logged.
    4/21/11 12:22:06 PM [0x0-0xb65b65].uk.co.squarebox.CatDVPro[21463] Thu Apr 21 12:22:06 joint-gamecap.wk.com CatDV[21463] : kCGErrorIllegalArgument: CGSGetWindowDepth
    David Jahns
    Joint Editorial
    Portland, OR
Page 2 of 2
