Activity › Forums › Apple Motion › Illustrator Vector Import in Motion – can it work?
Zak Peric replied 15 years, 4 months ago 5 Members · 24 Replies
Stephen Smith
May 11, 2011 at 8:41 pmHappy to help. Keep in mind that you can make your PSD a whole lot bigger so when you zoom in you can maintain more quality.
Stephen Smith
Utah Video ProductionsCheck out my Motion Training DVD
Check out my Motion Tutorials
Rogier Chardet
May 14, 2011 at 12:28 amIn the end I just used After Effects which had no problem handling the Illustrator file in question. The file was single-layered, by the way, so even without additional multi-layer complexity, Motion was failing.
Zack Olson
May 19, 2011 at 8:05 pmZak (and the Creative Cow “Cow-munity”),
On your recommendation I downloaded the 30 day trial of After Effects CS5.5 and am committed to struggling through the motion graphics process. I figure AE will better suit my needs as i am a heavy Illustrator user. I am confident in my Illustrator 2D workflow and would like to create a fully animated 30 second to 1 minute animation.
I am trying to scour the web, but most of the .AE tutorials are integrating video/photos and text. I have yet to find (after literally hours of searching) a good tutorial for how to animate, from scratch using (start to finish) Illustrator and After Effects in a style like this:
It seems like there should be plenty of info out there…any suggestions, or a tutorial that stands out?
Thanks in advance.
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Zak Peric
May 19, 2011 at 8:29 pmHave you tried subscribing to cows podcasts on after effects. There are tons of tutorials on animating with after effects. I think you should understand that animating a psd file is exactly the same as animatig a illustrator file. Just bring in composition crop layer and animate the layer the way you want it. Also try to post questions in after effects forum as I am sure people in that forum will be better suited to help you from now on.. Good luck.
