Activity › Forums › Apple Final Cut Pro › I have a scene in my film Final Cut Pro X HATES
Dennis Widmyer replied 12 years, 9 months ago 4 Members · 15 Replies
Dennis Widmyer
November 28, 2013 at 9:38 pmI’ve done a lot of reading on this. And I’ve even tried working in this particular Project at Standard Def (480) as a test, by moving just this scene into its own Project. And I’m already editing off transcoded 422 proxy files. So besides creating Optimized versions of all the files (which I’m not sure I have the disk space for now), I’m not sure what else I could try to improve the workflow. Again, this is the only scene in a 95 min film that is causing me problems.
Dennis Widmyer
http://www.parallacticpictures.com -
Dennis Widmyer
November 28, 2013 at 10:13 pmYeah, I’ve already tried the method of moving the scene into its own project. This is where I also tested it at different resolutions. 2K. 720p. Then 480p. And none of that helped. So yeah, I’m tempted to just reimport these specific scenes and then rebuild the scene from scratch. I’m just running out of time. :/
Dennis Widmyer
Bill Davis
November 29, 2013 at 8:49 amWell, if it’s just the one scene, I’d recommend you just open a new project. Cut and paste ONLY those clips into a small, self-contained timeline.
See if that renders and plays back OK. Even if it doesn’t – try Exporting JUST that small section as a Tiny Master Clip and then bring the “consolidated clip” back in to replace the complex construction of the original.
I haven’t needed to do this in X ever, but I used to do it with some frequency with my more complex constructions in FCP-Legacy.
So it’s worth a try. Let us know how things go.
Know someone who teaches video editing in elementary school, high school or college? Tell them to check out http://www.StartEditingNow.com – video editing curriculum complete with licensed practice content.
Jeremy Garchow
November 29, 2013 at 10:49 pmWhat effects are you using?
Have you tried breaking apart the compound clips?
You can select those two clips and choose to transcode them if you want. You don’t have to transcode everything.
Dennis Widmyer
December 4, 2013 at 2:31 amThis advice was tremendously helpful, guys. Thank you.
Dennis Widmyer
