Activity › Forums › Panasonic Cameras › I drank the coolaid
Jeremy Garchow
May 11, 2009 at 10:52 pm[Daniel Weber] “Does anyone have a link to the dual adaptor? I have searched but can’t find one. “
https://www.duel-systemsadapters.com/?productid=DP-0001
Search Duel Systems Adapter in the future.
[Daniel Weber] “Also, is shotput or the Panasonic software the best option? “
I like and use Shotput Pro. It allows ease of use and backup to three hard drives at once if you want.
P2CMS also works well, I have had no problems with it, you just have to remember to backup those transfers regularly during the day.
Jeremy
Daniel Weber
May 11, 2009 at 10:56 pmJeremy,
Thanks for the link. I have put in my order.
If I use P2CMS to copy the files to a drive can I then copy that folder over to another drive as a backup or do I need to use P2CMS again to make the duplicate copy?
Daniel Weber
Daniel Weber
Producer
Adventist Television Network -
Daniel Weber
May 11, 2009 at 11:00 pmDoes anyone have a link to the dual adaptor? I have searched but can’t find one.
I understand that just dragging and dropping the files from the P2 card to an external hard drive is asking for corruption problems.
Daniel Weber
Daniel Weber
Producer
Daniel Weber
May 11, 2009 at 11:02 pmThanks!!!
Daniel Weber
Daniel Weber
Producer
Jeremy Garchow
May 11, 2009 at 11:18 pm[Daniel Weber] “If I use P2CMS to copy the files to a drive can I then copy that folder over to another drive as a backup or do I need to use P2CMS again to make the duplicate copy? “
You don’t have to use P2CMS to make the second copy, but I would recommend using a file copier that has some sort of verify. If you spring for ShotPut Pro, you don’t have to worry about the backup as it backs up and verifies to up to three soources.
