Activity › Forums › Creative Community Conversations › I can forgive apple if…
C. Park seward
July 4, 2011 at 5:06 pmIf you want to remove clips from the Timeline but still maintain the total project duration and timing, you can replace clips with gap clips. This method prevents any ripple edits.
Select the clips or range you want to remove.
Choose Edit > Replace with Gap (or press Shift-Delete).
Final Cut Pro replaces the selection in the Timeline with a gap clip.That effectively disables magnetic timeline. Also, have seen demos where the magnetic timeline function can be turned off. It can easily be turned off by pressing the “P” button.
Best,
Park -
Scott Sheriff
July 4, 2011 at 5:15 pm[Tom Wolsky] “Use the position tool, or learn to edit with a magnetic timeline. It can’t be switched off. Everything has to be connected to a continuous primary storyline.”
That’s a buzzkill
Scott Sheriff
Director
https://www.sstdigitalmedia.com“If you think it’s expensive to hire a professional to do the job, wait until you hire an amateur.” —Red Adair
Where were you on 6/21?
Derek Andonian
July 4, 2011 at 9:38 pmI don’t like the fact that the transitions cover the entire line break between clips. In Premiere Pro, they only cover the top third or so, and if for some reason you want to make a transition asymmetrical you can nudge it over a bit and see how much of it is on either clip…
C. Park seward
July 5, 2011 at 12:10 amPlease see Izzyvideo at 9:50.
https://www.izzyvideo.com/final-cut-pro-x-tutorial/8-tools-in-final-cut-pro-x/
This shows how to turn off the magnetic timeline and position a clip exactly where you want it.
Best,
Park -
Chris Jacek
July 5, 2011 at 4:16 am[C. Park Seward] “Select the clips or range you want to remove.
Final Cut Pro replaces the selection in the Timeline with a gap clip.”This sounds like it will be a little frustrating, especially if you are jumping between FCPX and FCP7, since that is the same shortcut as “Ripple Delete” that you are using to not ripple it.
What’s next? Wearing hats on our feet, and hamburgers eating people??!?!!?
Professor, Producer, Editor
and former Apple Employee
