Activity › Forums › Blackmagic Design › Hyperdeck shuttle HDMI in adding set up to DNxHD file?
Levi Davis replied 14 years, 4 months ago 5 Members · 11 Replies
Levi Davis
May 19, 2012 at 6:46 amIt appears that converting the files from DNxHD.mov to ProRes utilizing the application called MPEG Streamclip is an easy answer. Test out the formula by referencing the simultaneous recording from the AVC HD format.
Just followed one of the user’s pattern for workflow inside of Premiere Pro CS 5.5… Rendered the entire work area and than exported to ProRes 422. The black levels appear to be just slightly higher than MPEG Streamclip’s levels by about 2 – 5 percent. Both appear to be viable solutions.
05-19-2012
