Activity Forums Panasonic Cameras HVX chip size???
  • HVX chip size???
    Posted by Paul C on April 25, 2005 at 11:30 pm
    Does anyone have any information regarding the imaging chips that will be used in the HVX200? I’m hoping for at least 1280×720.
    Bob Cetti replied 21 years, 5 months ago 8 Members · 19 Replies
  • 19 Replies
  • Graeme Nattress
    April 26, 2005 at 12:10 am
    1280×720 is the current “best guess”, but as no details have been revealed, it’s just a guess. All we were told at NAB is that Panasonic are optimizing for dynamic range, resolution and low noise, and that they’d give us the best on all three (or words to that effect.)
    Graeme
    http://www.nattress.com – Film Effects for FCP
  • Rodrigo Lizana
    April 26, 2005 at 12:41 am
    1/3″ I believe is the chip size. How many pixels inside that chips…let
  • Graeme Nattress
    April 26, 2005 at 1:01 am
    Chips are analogue devices. They don’t have bits.
    Graeme
  • Rodrigo Lizana
    April 26, 2005 at 1:07 am
    I meant the quantization of the video signal. Never said nothing about the chip having bits.
    Rodrigo Lizana
    PIXINE
    http://www.pixine.cl
    rlizana@pixine.cl
  • Graeme Nattress
    April 26, 2005 at 1:19 am
    Sorry. Nobody knows what the A to D converter will be, or the DSP. However, DVCproHD is an 8bit format, if that helps.
    Graeme
  • Rodrigo Lizana
    April 26, 2005 at 1:27 am
    Sure DVCPRO HD is 8 bits but the Varicam has a 10 bits HD-SDI port and since the HVX is going to P2 and not to tape under HD and DVCPRO 50 it could be possible…But I think the same as you. 8 bits. 🙂
    Rodrigo Lizana
    PIXINE
    rlizana@pixine.cl
  • Jan Crittenden livingston
    April 26, 2005 at 1:50 am
    Our current techology is 14 Bit DSP.
    Jan Crittenden Livingston
    Product Manager, DVCPRO, DVCPRO50, AG-DVX100
    Panasonic Broadcast & TV Systems
  • Graeme Nattress
    April 26, 2005 at 2:10 am
    Thanks Jan – that’s good to know. A good DSP makes all the difference!
    Graeme
  • Luis Caffesse
    April 26, 2005 at 2:23 am
    [Jan Crittenden Livingston] “Our current techology is 14 Bit DSP.”
    Thanks for the reponse Jan.
    Graeme, or someone else who would understands this technical minutia better than I do, could you give us a clear explanation of why a higher bit DSP is better for the final signal (considering DVCPro is an 8bit format)?
    And, at what point would there be no noticable difference?
    I mean, would we see a world of difference if we had a 16bit DSP, or a 32bit?
    (you see what I’m getting at)
    Luis Caffesse
    Studio 3 Productions, Inc.
    Austin, Texas
  • Graeme Nattress
    April 26, 2005 at 2:30 am
    The CCDs can take in a range of light that is quite large. To fit this range better into video, and to get around some of the limitations of 8bit video, the image is gamma corrected to about 0.45 before being turned into 8bit video. This obviously needs to be done at a higher precision than 8bits to make the 8bit result as good as possible. Monitors have a gamma of about 2.2, which cancels out the 0.45 gamma correction so that we again see the correct image upon display.
    The limits of DSP bit depth are really the noise floor of the CCD and the type of processing that you want the DSP to do. 14 bits sounds more than enough, but I’m surprised that they just don’t go to 16bits as word lengths of 16 usually compute better, even if it’s offering an extra 2 bits you don’t need. Any video DSP programmers here?
    Graeme
