Activity Forums Adobe After Effects HOW TO USE AE7 WITH INTEL MACS
  • Graham Jones
    November 5, 2007 at 3:39 pm
    Hi Andrea,
    Thanks for your kind comments. I’m glad you were able to get good use out of my findings.
    Cheers,
    Graham Jones.
  • Jack Tunnicliffe
    November 5, 2007 at 5:40 pm
    I’m assuming the 59.97 you speak of is just a typo. There is no such frame rate. 59.94 would be the correct number.
  • Andrea Stewart
    November 7, 2007 at 1:28 am
    Silly me. Yes I meant 59.94.
    FYI, I rendered this :15 open last night and it took 17 hours! But, hey, it never quit on me, so that’s a blessing.
    I’m sure its the lights and motion blurs and nested pre-comps, etc. Though I have to say, most of the thing is vector art in HD pre-comps in an HD comp. You wouldn’t think it would be so RAM intensive.
    Looking into networking all our computers so I can render at night using our small group of Macs as a render farm.
    Andrea Stewart
    Producer/Editor/Director – Owner
    Germane Creative LLC
  • Graham Jones
    November 7, 2007 at 2:54 am
    Hi Andrea,
    have you considered pre-rendering any of the nested comps? It’s amazing how much faster renders go when you pre-render stuff that doesn’t need to change very often.
    Even if you get a render farm going, pre-rendering what you don’t change that often will help you work much more quickly… that and lower resolution proxies.
    Hope this helps,
    Graham.
  • Rowan Wernham
    October 20, 2008 at 3:01 am
    Hi – did you ever get this problem fixed?
    I am working on a 2K project with some very large BG’s (up to 8000px X 1600px)
    It renders fine at half quality or lower but hits the “Unable to allocate … image buffer” error on full quality.
    I have tried lowering my memory percentages even down to around 30% and setting a 5GB disc cache and purging all caches etc.
    I am using AE8.0.0.2 (CS3, still shy of any updates..) on a quadcore intel mac pro with 10GB of ram.
    I can live with not being able to render at full quality for now and the deadline is months off, but I will eventually need to output this at full res!
    Cheers!
    Rowan
  • Rowan Wernham
    October 20, 2008 at 3:43 am
    I think I may have found the answer right after I posted this..
    https://generalspecialist.com/2006/11/avoiding-after-effects-error-could-not.asp
    Managed to render one frame out by setting my maximum RAM cache right down to 10%
    Another frame I tested hit the buffer again but I think maybe I could get around this by using the secret pref which enables you to automatically purge after every frame!
    seems a bit sucky and may end up buying Nucleo Pro which apparently will also get around this issue?
  • Darren Manden
    July 12, 2010 at 9:58 pm
    Although this thread has been dead for a LONG time, I thought I’d add a post just in case someone was sitting in a similar situation to me.
    I’m still using AE 7 on an Intel Mac Pro Dual Xeon 2.8 GHz Quads with 12 GB RAM (I know, why not just get a new AE when using this machine? Well…it’s coming soon). Anyway, I used to have occasional buffer issues, but recently, after upgrading to Snow Leopard, AE would hang on pretty much any render. Thankfully the workaround regarding dropping the memory down works FANTASTICALLY well!
    I just thought I’d post and let anyone using an Intel Mac running Snow Leopard and AE 7 know that this works well. Thanks to Graham for originally figuring this out! You’ve saved me countless headaches!!!
  • Graham Jones
    July 13, 2010 at 1:28 am
    Thanks for the update; glad to be of service!
    Cheers,
    G.
Page 9 of 9
