Activity › Forums › Avid Media Composer › How To Sync Audio and Video Clips one by one Using Avid Media Composer 6
Michael Phillips replied 6 years ago 6 Members · 21 Replies
Laura Jones
July 29, 2020 at 5:55 pmive tried what you suggusted and it still did not work it kept playing the audio only.
Laura
Pat Horridge
July 29, 2020 at 6:10 pmYou’ve transcode the clips. They play OK but when you sync them they nolonger play?
Pat Horridge
Broadcast & Post Consultant, Trainer, Avid Certified Instructor
Free online Tutorials at VET digital media academy online http://vimeo.com/channels/752951
pat@vet.co.uk -
Michael Phillips
July 29, 2020 at 8:53 pmTest 1: edit source video clip into its own timeline. Does it play all the way through?
Test 2. edit audio source clip into its own timeline. Does it play all the way through?If yes to both, it’s only when these two clips are combined into a single timeline and both are playing at the same time that you get no video and only audio?
Michael
Laura Jones
July 31, 2020 at 8:50 amYes that is correct Michael when i play the video clip in its own timeline it plays all the way through and when i play the audio clip in its own timeline it also plays all the way through it is only when i combine the two (when the clips are auto synced) that there is no video and only a few seconds of audio once the clips have been autoscyned.
Laura
Pat Horridge
July 31, 2020 at 11:18 amCan you WeTransfer or uoad somewhere a short video and audio clip so people can’t test on their systems?
Pat Horridge
pat@vet.co.uk -
Michael Phillips
July 31, 2020 at 12:52 pmThen I would open a support case with Avid on this one.
Michael
Laura Jones
August 4, 2020 at 1:29 pmYes that is correct Pat only a few seconds of the audio plays there is also no image when the clip is played after it has been synced
Laura
Glenn Sakatch
August 5, 2020 at 2:53 pmIt sounds to me like the clips are not syncing maybe the common spot,( time code, in point, what ever you used) was incorrect, so the audio is not lining up with the video…so it is playing back a section before or after the video.
As pat said, posting a sample might be the fastest way to make sure we are all on the same page.
Glenn
Eric Santiago
August 5, 2020 at 3:34 pm[Glenn Sakatch] “It sounds to me like the clips are not syncing maybe the common spot,( time code, in point, what ever you used) was incorrect, so the audio is not lining up with the video…so it is playing back a section before or after the video.”
That has happened way too many times in Avid for me.
