Activity › Forums › DSLR Video › How to – Shoot in low light and reduce noise on Cannon 550D
Brendan Ross replied 16 years, 2 months ago 12 Members · 33 Replies
Steve Crow
July 11, 2010 at 5:44 pmGood job! Just a couple more suggestion:
At 1:10 the color balance abruptly changes, Final Cut has a match color feature that you could use to get the wall color looking the same in both clips.
Also, check the scene where he is putting his clothes on the hangers in the dresser. There’s a cut there that’s not matching – somewhere around 1:34/1:35 resulting in a jump cut.
Oh and does the room number matter? If not, I’d cut the tilt up.
Clyde Villegas
July 12, 2010 at 5:55 amAfter seeing how much the video skews, I think I’ll stick with the camcorder + lens adapter setup for a while.
ut in omnibus glorificetur Deus
Brendan Ross
July 20, 2010 at 7:29 amHi Steve
Please would you clear 1 thing up for me. I’m 550d / T2i user. regarding the rule of double the shutter speed of your fps. Here you talk about 24fps and 1/50. Why would you not use 25fps ? (i presume it’s also an option on the 7D.)
thanks
Brendan
