How to retain video effects and quality of video in Sony Vegas?
John Rofrano replied 12 years, 3 months ago 4 Members · 33 Replies
John Rofrano
May 28, 2014 at 11:42 am[Tiffany Klaus] “Are you talking about the max or avg bitrate?”
Average bit rate. Max and Min only sets the upper and lower limit that is allowed to be used, but overall the Average is what determines the size of the video. In other words, if a frame has a lot of detail, the encoder can use up to the maximum bit rate, but it then needs to lower the bit rate for other frames because by the end of the video, it must average out to meet the average bit rate.
[Tiffany Klaus] “Also, is there a way, if any, to make my video look exactly the same or very similar to my project? I just want to try to make it look very close to the project because the video is a bit too bright for me.”
As I stated earlier, set your preview to Best(Full) and your rendered video should look exactly like what you see in the preview. You also might want to check you work using the Secondary Monitor option above the preview window. It will work even if you only have one monitor. This will give you a full screen view of your video as it should look when rendered.
I may have already pointed out that some players adjust your video so you can’t trust any one media player; they all look a little different. Always drop your rendered video back onto the Vegas Pro timeline to check how it “really” looks.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Tiffany Klaus
May 29, 2014 at 4:51 amOkay. I got it. Sorry for sounding redundant. I just wanted to know all of options.
Anyways, thank you so much for your help, John. Your answers to my questions were really insightful and useful. You helped me dramatically improve the quality of my video. Also, thank you for the quick, simple, coherent, and concise responses. I truly learned a lot more about Sony Vegas from this thread. Thank you.
John Rofrano
May 30, 2014 at 12:12 amYou’re very welcome Tiffany. I’m gad you found this helpful.
~jr
