Activity › Forums › Adobe After Effects › How to replace this green screen?
Roland R. kahlenberg replied 14 years, 4 months ago 4 Members · 13 Replies
Josh Pigford
May 24, 2012 at 8:19 pmThis is what I’m referring to:
You can see where, to get a decent key, I had to bump up levels a good bit. I’ve got a garbage mask already (as you can tell), but I don’t know how I’d get around this without pulling shape data out of mocha to mask every green area.
Maybe I’m missing something obvious though…
May 25, 2012 at 1:21 amYou will need to export mocha shape as well as the corner pin data. In AE, the mocha shape goes into a solid which will then be used as a track matte layer. mocha shape only contains shape & transform data – ie no perspective information.
mocha’s Corner-pin data will be used on the fill layer (ie layer beneath the track matte layer).
BTW, mochaAE/mochaPro V3 includes 3D camera solve. Go here to view a related tutorials.
HTH
RoRKIntensive AE & Mocha Training in Singapore and Malaysia
Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer -
May 25, 2012 at 1:29 amBTW, you do not need markers on the edge of the cards – they just make it more difficult to remove. Just place markers in the middle of the cards. This is ideal since the card is a single plane. Your mocha spline just needs to encompass the markers while the surface area can be a larger area than the spline.
HTH
