How to render without losing quality?
Paul Hinderscheid replied 10 years, 8 months ago 2 Members · 13 Replies
Graham Bernard
January 10, 2016 at 10:16 amDid you create the Text item? You may need to change/match the resolution.
The Levels is a different/other issue.
* Grazie
Cameras: Canon XF300 + PowerShot SX50HS Bridge -
Graham Bernard
January 10, 2016 at 11:17 amYou could also try 2-Pass render.
* Grazie
Paul Hinderscheid
January 10, 2016 at 10:43 pmTried 2-Pass and raised the bit rate all the way, didn’t change anything. I’m not sure what you mean about the text item, I just created the text in Photoshop and saved as .png image. There’s six images in total from my graphic design work that I imported to Vegas, when rendered only two of the images look compressed and it’s very obvious but the other four images don’t look compressed at all crystal clear which is weird. I’m not sure why only two images look compressed. All are the same resolution size and everything. I wish I could figure out what’s wrong.
-Paul
