Activity Forums Adobe After Effects How to render graphics in 1080i 50.
  • John Mark
    August 1, 2013 at 12:50 am
    I have rendered my graphics at 25fps using Upper feilds. I stil dont get the smooth motion I’m looking for in 1080i50 (TV 1080i50hz) I don’t understand, my vide clips running at 25fps play silky smooth, why not for the graphics?
    A News Graphic Lover
  • Walter Soyka
    August 1, 2013 at 1:58 am
    [John Mark] “I have rendered my graphics at 25fps using Upper feilds. I stil dont get the smooth motion I’m looking for in 1080i50 (TV 1080i50hz) I don’t understand, my vide clips running at 25fps play silky smooth, why not for the graphics?”
    How are you monitoring?
    Can you post screenshots of your comp settings, your render settings, and your output module?
    Walter Soyka
  • John Mark
    August 1, 2013 at 2:10 am
    [Walter Soyka] “How are you monitoring?
    My final output is going to a HD TV (1080i50hz) using a Black Magic UltraStudio Mini Monitor.
    My After effects Settings: https://images.creativecow.net/240404
  • Walter Soyka
    August 1, 2013 at 7:54 pm
    [John Mark] “My final output is going to a HD TV (1080i50hz) using a Black Magic UltraStudio Mini Monitor.”
    And is that what you are watching when you don’t see smoothness? Please describe the entire playout process.
    [John Mark] “My After effects Settings: https://images.creativecow.net/240404
    Please also post your render settings so we know what output format you’re using.
    Walter Soyka
  • John Mark
    August 1, 2013 at 10:19 pm
    [Walter Soyka] “And is that what you are watching when you don’t see smoothness? Please describe the entire playout process.
    Yes, the graphics are running from Softron OnTheAirExpress, then outputting via a UltraStudio mini monitor. This is were I don’t see the smoothness, even with upper fields in use.
    This is the render settings of “best settings” : https://f1.creativecow.net/6355/6355?uploaded=file
    If this is not what your after I apologize and will post the correct information.
    As for Dave questions:
    As in, “Are you using the proper media container and codec for your blackmagic card?”
    All my graphics, I use animation, just for the use of alpha channel.
    As in, “Do you have the proper storage to support the bitrate for the Blackmagic-recommended media container and codec to which you rendered?”
    I have purchases a new Macbook pro I5, with hardly any usage yet. Video clips play smoothly in a codec “Apple International codec”. I have tried converting my graphics in After Effects using the same settings as my video clips, but it does not seem to work still
    Thank you both for your time and patience.
  • Walter Soyka
    August 2, 2013 at 3:27 pm
    [Dave LaRonde] “I bet you actually mean “Apple INTERMEDIATE Codec”. Two words: it stinks. Never, EVER use it for graphics. “
    Dave was a lot kinder to AIC than I would have been… it’s utterly horrendous. Avoid it like the plague.
    AIC was Apple’s proprietary, thin-raster mezzanine format for HDV. It may not support square-pixel 1080i50.
    [Dave LaRonde] “Your goals dictate that you get a far more robust storage solution with much higher throughput than you currently have. I’m not conversant on the latest hardware, but I’m sure the Good Mr. Soyka will have some suggestions.”
    Thank you, Dave!
    John, I’d suggest trying to render to Apple ProRes 422 before throwing hardware at it. You should be able to play a stream or two without any trouble.
    Walter Soyka
  • John Mark
    August 2, 2013 at 5:24 pm
    [Dave LaRonde] “If you’re doing this just for fun, you picked one mighty expensive hobby, sir!
    I certainly didi!
    Thank you both for your time, help and tips. I will try rendering at Apple ProRes and see how I go.
  • John Mark
    August 3, 2013 at 1:16 pm
    Finally! Everything is working like I want it to. The end solution was I had to render at 50fps “using upper fields” and not 25fps. Thank you once again for your help.
Page 2 of 2
