How to avoid long renders from Vegas
Mike Kujbida replied 15 years, 2 months ago 4 Members · 16 Replies
Mike Kujbida
July 26, 2011 at 1:37 pm -
Mike Kujbida
July 26, 2011 at 1:42 pm -
Ken Matson
July 26, 2011 at 1:44 pmNo … sorry … i meant “determine the bit rate of the existing video i imported”
KenM
Sound Works R&P -
Ken Matson
July 26, 2011 at 1:48 pmOK – i was looking for a way to select AC3 for the audio portion under the MPEG2 output type.
Also – what’s the difference between the “DVD” and “MPEG2” output options? i thought DVD WAS MPEG2?
Really appreciate all the hand holding here – quite new to this stuff .. old audio guy … but i usually catch on quick once i get going!
KenM
Sound Works R&P -
Mike Kujbida
July 26, 2011 at 5:25 pm[Ken Matson] “No … sorry … i meant “determine the bit rate of the existing video i imported””
Sorry Ken but, as I said earlier in this thread, I know there are free tools out there to give you those numbers but I don’t use them so I can’t make any suggestions.
I recommend starting a new thread and ask if anyone has any suggestions. -
Mike Kujbida
July 26, 2011 at 5:31 pm[Ken Matson] “OK – i was looking for a way to select AC3 for the audio portion under the MPEG2 output type.”
They get rendered separately so that’s why the different options.
[Ken Matson] “Also – what’s the difference between the “DVD” and “MPEG2″ output options?”
“DVD NTSC” gives you a stream that already has the audio embedded in it while “DVD Architect NTSC video stream” gives you an mpeg-2 only stream which is what DVD Architect really wants to see.
“Really appreciate all the hand holding here – quite new to this stuff .. old audio guy … but i usually catch on quick once i get going!”
Not a problem at all.
Since your expertise is in audio, we can look forward to you answering the numerous audio questions that always pop up 🙂
The world of video can be confusing at first but I have no doubt that you’ll catch on in no time.
Enjoy it as it’s a lot of fun.
