Activity › Forums › Apple Motion › How to achieveGraphic Novel Style?
Stephen Smith replied 16 years, 1 month ago 5 Members · 17 Replies
Pradip Patil
July 29, 2010 at 5:27 pmThanks…
But the more I think the more doubts arise. Should this type of project be done completely in Motion?
I am more used to edit in FCP and then “send to motion” kind of workflow and then applying filters inside motion.
Since all the shots will be inside frames/panels, it makes sense to build the pages in 3D environment and then use the camera behaviours to focus on each panel.
Right?Pardon me for such questions but have never worked in 3D motion projects.
Stephen Smith
July 29, 2010 at 5:33 pmIf you want to move around from panel to panel then yes, you should do it in Motion. If there are any hard cuts or something use that as an opportunity to create another project file so your project files are not to big. Those filters I mentioned are in FCP as well. However, If I built the Target add I would have built it all in Motion. Hope this helps.
Stephen Smith
Utah Video ProductionsCheck out my Motion Training DVD
Check out my Motion Tutorials
Pradip Patil
July 29, 2010 at 5:46 pmHmm.. Now things are falling in place.
One more question,
Any suggestion on placing the frames/panels? I don’t want the space to be cluttered.
Need some project organizing ideas for such kind of work. -
Stephen Smith
July 29, 2010 at 5:52 pmI think it would be best to keep each frame/panel in its own group. Be sure to name the groups so it is easier to find things when you need to make changes. If you wan the panels to be the same you can build your one group then duplicate it so it is the same, then make tweaks inside the panel as you see fit. This sounds like this is going to be a lot of fun. You’ll have to post it so we can see it when it is completed. Best of luck.
Stephen Smith
Pradip Patil
July 29, 2010 at 6:00 pmYes..
And this is just the beginning.. I will be back with a lot of questions tomorrow.
Thanks for the support
Mark Petereit
July 29, 2010 at 6:05 pm[Pradip Patil] But the more I think the more doubts arise.
LOL! Then stop thinking about it and just start creating! 😉
Stephen Smith
July 29, 2010 at 6:05 pmSounds great.
Stephen Smith
