Activity › Forums › Apple Final Cut Pro Legacy › How often does FCS2 crash?
Sean Oneil
January 29, 2008 at 6:08 am6.02 is very stable compared to earlier versions of FCP 4-6.
Sean
Carl Cimini
February 1, 2008 at 2:01 pmCheck all your connections, particularly you video connections, macs are very sensitive to back up charges and can even short out. After you are absolultely sure you have every connected secured do a hardware check using your orginal os install disk. If you are messing around on line with you computer ie xxx you could have had a few files go south but it isn’t fcp2. The hardware check takes about 3 hours but it’s worth it and will also reinstall the necessary fixes. Just some thoughts. Not in anyway an expert.
