Activity › Forums › Apple Final Cut Pro Legacy › How does one remove hits / dropouts?
Howie Young replied 21 years, 1 month ago 8 Members · 17 Replies
Vince Sanchez
August 20, 2005 at 3:11 amunfortunately only v4 on up.
Try contacting them, maybe they can do something for youhttps://www.digital-heaven.co.uk/indexflash.htm
Vince Sanchez
G5 DP2.0ghz 2.5gig ram
AJA IO
OS10.3.9 QT7.01
3X250gb SATA Hitachi HD 8meg cache stripped in array
Sonnet 133mhz Sata card
OWC firewire card -
Tig Coates
August 20, 2005 at 4:45 amIf you can’t fix it with just fields
then Combustion has Re:Flex
so a short morph may helpTig
Andy Mees
August 20, 2005 at 5:26 amfor clone and paint capabilities you might want to look at Re:Fill or Clone at
https://www.revisionfx.com/rfil.htm or https://www.chv-plugins.com/clone.html respectively
both work in FCP 2 -
Tony
August 20, 2005 at 5:08 pmHowie,
What tape format did you record in?
Betacam, DV, digi beta, dvcpro? What was the camera model you used in the field?
Have you confirmed that it was the field recorder which caused the problem or is there a chance your playback vtr has damaged the tapes?
Items to check on your playback vtr
1)Manually clean the playback vtr heads and tape path using 98% alcohol and head cleaning cloth.
2)Make sure the pitch roller is not shiny if it is this may indicated need to replace itYou must confirm where the problem occurred during recording or upon playback to avoid future damage to tapes.
Tony Salgado
Howie Young
August 21, 2005 at 4:05 pmTony
Thank you for the tips. I only have a VHS copy of the footage. It would appear that the hits are on that tape.
Howie
