Activity Forums VEGAS Pro How do I zoom text smoothly
  • Laszlo Kovacs
    June 28, 2007 at 4:21 pm
    [Mike Kujbida] “Aother suggestion is to double the text size and there will be a difference in the final quality.
    This is done in the size boxes in the Text Event FX box.”
    I agree, but also disagree this.
    As I mentioned, create the text with a size that is aproppriate for the maximum zoom you plan. So the double size may be good, may be overkill, or may not be enough.
    Depends on your zoom level 😉
    By(t)e
    K.L.
  • Mike Kujbida
    June 28, 2007 at 5:35 pm
    [Laszlo Kovacs] “I agree, but also disagree this.”
    I came across this tip (doubling the text size) at least 3 years ago and have been using it ever since.
    I don’t see any performance hit and, as I said, even without doing any zooming, my text is definitely cleaner.
  • Joe Gaziv
    June 28, 2007 at 8:04 pm
    great!
    The pan/crop works nicely.
    Will you direct me, step by step to the “track motion” method ?
  • Mike Kujbida
    June 28, 2007 at 9:08 pm
    Don’t bother with Track Motion for zooming.
    It’s great at moving images around the screen or shrinking them down and placing them in a certain position.
    If you started with a still image that’s 2500 x 1600 pixels, it changes this to your project size (720 x 480) and zooms in on that. As you can imagine, the result, especially if you do a 2X or 3X zoom, will be unacceptable.
    OTOH, Pan/Crop retains the image’s original size when zooming which is why it’s the preferred tool for doing this.
  • Joe Gaziv
    June 29, 2007 at 6:09 am
    Thank you guys for the help.
    BTW I zoom in pan/crop by pushing the diagonal handle (IE cut and try). Is there “more professional” way ?
Page 2 of 2
