Activity › Forums › Adobe Premiere Pro › how do i get premiere to find “missing” AE video filters?
  • how do i get premiere to find “missing” AE video filters?
    Posted by Tad Newberry on October 31, 2013 at 8:08 pm
    i don’t get it. i imported an AE project that a friend did into Premiere, yet it keeps telling me upon start up that four video filters are missing. 3 of those 4 filters show up in AE, but why can’t Premiere see them?
    they are listed thusly:
    Video Filter missing: AE.ADBE 3D Tracker
    Video Filter missing: AE.ADBE Fractal Noise
    Video Filter missing: AE.ADBE Glo2
    Video Filter missing: AE.CS CrossBlur
    “Glo2” is the one that didn’t show up in AE, though “Glow” did. Any ideas?
    thanks for helping out a bonehead!
    __________________________
    FCS3
    2.66 GHz Quad-Core Mac Pro
    6GB RAM
    NVIDIA GeForce GT 120
    …and a few TeraBytes o’ storage
    (then it’s on to PetaBytes, ExaBytes and MosquitoBytes!)
    Joe Bloemer replied 5 years, 1 month ago 8 Members · 12 Replies
  • 12 Replies
  • Tero Ahlfors
    November 1, 2013 at 7:22 am
    AE and Premiere do not share all effects.
  • Tad Newberry
    November 1, 2013 at 3:12 pm
    so how do i go about getting those effects and filters into Premiere?
    FCS3
    6GB RAM
  • Ivan Myles
    November 1, 2013 at 4:03 pm
    Do you have a copy of After Effects? If so, create a Dynamic Link to the AE file from Premiere Pro.
  • Tad Newberry
    November 1, 2013 at 4:10 pm
    Hi Ivan,
    Yes, i do have AE. I have the Cloud subscription. How might i go about creating this dynamic link? (This is why i’m on the basic forum). Thanks!
    FCS3
    6GB RAM
  • Ivan Myles
    November 1, 2013 at 10:23 pm
    In Premiere: File > Adobe Dynamic Link > Import After Effects Composition…
    Navigate to the file and select the desired composition. There is more information here.
  • Jonas Bendsen
    March 29, 2014 at 7:56 pm
    Lots of suggestions here for how to fix by creating a Dynamic Link, but how does one simply find where the non-working filter was applied in order to remove it? That was the original question, and that’s the answer I came here looking for. Anybody got a suggestion?
    For the record, this error is popping up for me in a Premiere CS6 project that was imported from an earlier version of Premiere, so while it’s a compatibility issue, it has nothing to do with After Effects.
    edit: Oddly enough, the error is calling it an AE filter (AE.RG MBCC –I’m assuming that’s Magic Bullet Colorista?), but I’ve never even opened AE.
    This is my life, I edit and edit and edit and edit…
  • Mike Tombeur
    July 13, 2014 at 3:46 pm
    just wondering if you ever found a solution for this missing filter issue… having the same problem..
    M
  • Dustin Parsons
    November 29, 2014 at 9:02 pm
    Same problem here, 2 missing filters but I don’t know where they are:
    Video Filter missing: AE.ADBE CurvesCustom
    I don’t have any Direct Link clips, just clips I’ve exported from AE. Any help on finding where in my project these filters are being used?
  • Lucas Salles
    June 26, 2018 at 7:45 pm
    Hello folks!
    I had similar issue and it was caused by a missing plugin that works for both Ae and Pr, I use flicker free which normaly it’s inatalled on a common folder for both apps, since I installed again the plugin but this time in a diferent disk, I started having the issue, I tried to open a project in Premiere and got the message
    Video Filter missing: AE.Digital Anarchy Flicker Free
    I solved the issue reinstalling the plugin at the adobe common path, in my case something like that:
    C:\Program Files\Adobe\Common\Plug-ins\7.0\MediaCore\
    Now all working just fine.
    Cheers!
  • Lucas Salles
    June 27, 2018 at 1:16 pm
    Hello folks!
    I had similar issue and it was related to a missing plugin from the common folder, used by AE and PR as a shared plugin folder.
    My issue started when I got a video from work where I have flicker free installed and bought to edit at home where my flicker free was installed on the plugins folder inside AE instead of the common folder.
    I just re-installed the plugin oh the default folder and ll is fine again.
    In my case the path was:
    Hope this may help.
    Cheers!
    Lucas
