Activity › Forums › Adobe Premiere Pro › How do I add Subtitles
Dmitri Sled
January 28, 2016 at 2:25 amTHIS!
For folks trying to decide on the best workflow approach to subtitling – especially if it’s a big job with hundreds of subs – I would strongly urge you to take up the InDesign route!
Neither Premiere nor AfterEffects are practical for burned-in subtitles. At the very least, if you are considering this option, make sure you have your subtitle font style/size/color/etc locked down and confirmed with everyone and anyone you are working for, because once you settle on it, the ONLY way to change it is by re-opening each individual title. Changing the subtitle style mid-stream will result in hours of repetitive and needless (but hopefully still highly paid) work.
InDesign, on the other hand, is a lot more flexible in this regard. It might sound “counter-intuitive” (or rather, like a cheap-o bandaid/ducttape half-fix) to export hundreds of PNGs and plop them into Premiere, but that seems to be the absolute best way to go about things.
Sabreena Pe
February 22, 2016 at 9:11 pmHi Steve,
Thanks for posting this. I tried using this method, but for some reason the subtitles don’t actually show up when I bring them into Premiere Pro. Any suggestions on why this might be, or what I can do?
thanks,
Sabreena
Mike Dunaway
March 12, 2016 at 11:50 amHi Sabrina,
Please try using our newly released app titlebee, that lets you create broadcast-quality subtitles, modify styles and animations and then export as an alpha layer for premiere pro or burn them directly onto your video.
You can find out more here: https://www.titlebee.com/
Thanks, Mike
Anna Redkovska
July 27, 2016 at 9:37 amDear Paddy (or anyone else who knows the answer),
how do you actually add the translucent box to the subtitles without any plugin?
I never found an option of changing the titles’ background size… -
Paddy Uglow
July 27, 2016 at 3:41 pmPremiere Pro lets you draw boxes in the Titler, and you can set the opacity of the fill on them, and arrange them to be behind the text.
Paddy, CreativeMedia.org.uk
Julien Beaumier
November 6, 2016 at 11:33 pmFor anyone using Premiere CC wanting to make burned in subtitles, here’s the best way to do it. It’s so much quicker than using the title tool!
https://helpx.adobe.com/fr/premiere-pro/how-to/subtitles.html
