Activity › Forums › Adobe Premiere Pro › How can I edit and export 48fps footage in Premiere CS4
Clayton Orgles replied 13 years, 7 months ago 8 Members · 32 Replies
Noland Orozaco
February 7, 2013 at 10:53 pmThe fact that it is exactly 48 fps is a very important part of the project =)
Noland Orozaco
February 7, 2013 at 10:54 pm -
Peter Berthet
February 8, 2013 at 12:44 amok.. but my point is, for the headache involved in working in a non standard format, nobodys gonna see the difference between 48 and 50
– Pete
Peter Berthet
February 8, 2013 at 12:51 amI just did a few tests and the only thing i could get to render correctly at 48fps was a quicktime animation file.
Everything else hated it.
– Pete
Noland Orozaco
February 8, 2013 at 1:16 amWhen I use animation codec the filesizes are huge, at 1080p not even a high end computer could run it smoothly. I’m really confounded here, any other ideas?
Shane Ross
February 8, 2013 at 1:18 amBut can the projector play back 50fps? That would be PAL, right? 48fps isn’t PAL…it’s an odd frame rate. If the projector plays back that rate, it would have to be that rate exactly, no? 50 isn’t the same as 48. There’s more involved there.
What brand of projector is it?
Shane
Little Frog Post
Read my blog, Little Frog in High Def -
Shane Ross
February 8, 2013 at 1:31 amAnd I’m wrong about the web and 48fps…it’s very doable:
https://www.hfrmovies.com/The_Hobbit_An_Unexpected_Journey_Trailer.mp4
Shane
Little Frog Post
Peter Berthet
February 8, 2013 at 1:32 amthats kinda what you’re gonna find using a non-standard format
i can play animation quicktimes from my system here coming off a 2xsata drive RAID.
is there a reason your client requires 48fps ?
what will be the means of display for the final product ?– Pete
Noland Orozaco
February 8, 2013 at 1:35 amLet me give you all the information I have.
The purpose of the clips I’m making is to compare motion blur at different framerates.
The client wants quicktime h.264 files at many different fps.
The clip I’m working at now needs to be exactly 48fps so that it can be compared to other clips at different fps.
They need to be viewable on a computer and be projected. I’ve been assured that the projector can run quicktime h.264 48fps 1080p footage. I don’t know the details about the projector, but I’m not really involved in the projection process. I just need to deliver quicktime, h.264, 48fps, 1080p. -
Peter Berthet
February 8, 2013 at 1:38 amOf course its not the same Shane, but it is more manageable from an edit and delivery point of view
– Pete
