Activity › Forums › Apple Final Cut Pro Legacy › Horizontal Line EVILNESS – HELP
Jeremy Garchow
July 24, 2008 at 6:47 pmYou need another drive with 45.29 GB. How much room does you other Lacie have on it?
Rory Turner
July 24, 2008 at 7:09 pmThe other one is maxed. there is only 7 GB left. The first sequence 1 quick time movie took up 63.64 GB. I just got an idea I”ll dump everything from the first Lacie on to the FAT32 Lacie which should give me enough space to finish it with out reformating everything.
Jeremy Garchow
July 24, 2008 at 7:13 pmNO! Don’t do that.
just delete sequence 1 on your first Lacie, then backup Lacie 2 on to 1. Reformat 2 and then export botth to lacie 2.
Jeremy
Christopher Griffin
September 22, 2009 at 12:11 pmI am having this same problem. I have two external drives, both formatted to Mac OS Extended.
I do not have compressor, just FC. No matter what format I export to, I get the horrible horizontal lines.
Jeremy Garchow
September 22, 2009 at 3:48 pm[christopher Griffin] “No matter what format I export to, I get the horrible horizontal lines.”
Is your footage interlaced?
