Activity › Forums › Apple Final Cut Pro Legacy › hooking up two monitors to a new MacPro
Lang Elliott replied 17 years, 5 months ago 6 Members · 13 Replies
Shane Ross
April 13, 2009 at 5:50 amATI! Gah, sorry.
Shane
Read my blog, Little Frog in High Def -
John Steventon
April 13, 2009 at 7:54 amThat’s exactly what I do. I’ve got 2 x 23inch monitors, one on the main port, one on the mini-DVI port. However, any worrys about colour from the mini-DVI (if there are any) have always been overcome by using an external video monitor (through a Decklink HD Extreme 3 card).
It all works perfectly for me…. so far.
John
John Steventon
JKL Editing
http://www.jklediting.com
“Success is merely a failure to imagine more…” -
Lang Elliott
April 13, 2009 at 3:37 pmThank you Scott for a simple solution.
But returning to a subject brought up elsewhere, I understand it is not possible to use the new Apple LED display in the miniDVI port and then use the DVI connector for a second monitor . . . because Color doesn’t like this kind of setup. Is this correct? I remember reading that one must get the miniDVI-to-DVI adapter and use two older Apple monitors to keep Color happy.
