Activity › Forums › Panasonic Cameras › hmc 150, final cut express 4 and 2.8GHz (intel duo core)iMac
Tim Dumont replied 17 years, 8 months ago 4 Members · 15 Replies
Masud Haq
December 19, 2008 at 4:43 amI tried the 720 modes on the AG-HMC150. Here are the results. In FCE 4.01 I have set Easy Setup to be AIC 720p30 for of the following.
With PH 720/60p record mode on the camera, FCE imports the clips and the sound perfectly and in sync. There is none of the jerky-ness in the first few seconds (or anywhere in the clip) that I saw in the 1080/30p record mode. No green frames either that I saw in the first few seconds of 1080/30p clips.
With PH 720/30p record mode on the camera, FCE will play the clip in the log and transfer window fine, but when ingested and transcoded into AIC the video plays twice as fast and the duration of the clip is half as long. The sound, however, plays at normal speed so the AIC clip has only the first half of the original sound track. Naturally video and sound are out of sync. This issue has already been reported in other posts and in other forums. In this mode there is no jerky-ness or green frames.
Here is some additional information. When the PH1080/30p recorded clips are transcoded to AIC, the data rate ranged from 12.5 to 15 Mbps. With the PH720/60p clips I am getting between 9 and 10 Mbps on the transcoded AIC. So per pixel I am getting about 50% better data rate on 720 than 1080. The unfortunate thing is that the recorded data rate in both averages about 21Mbps, so a lot is lost when transcoding to AIC.
Stepping up to FCP with ProRes 422 or ProRes 422 (HQ) instead of AIC should let us take advantage of the additional recorded data rate. Additionally FCP should also handle the 24p modes (PH1080/24p and PH720/24p) natively – I did not even bother testing these on FCE. From what I have seen in other forum posts, the speed issue with 720/30p is still there in FCP – until a future fix/update by apple.
Michael Fountain
December 19, 2008 at 5:14 amMasud,
Thanks for posting…Great info for us FCE users!
Masud Haq
December 19, 2008 at 7:37 pmQuick update on recording a 720/60p in the camera and ingesting into FCE:
For some clips, especially in bright light with a lot of detail in the scene, I am seeing some gray or colored bands appear in the video. in a 98 second long clip I saw two occasions of this banding each less than 2 seconds in duration.
When I play the same clip directly from the camera on an hdtv using the HDMI cable, the banding is not there. However the banding is there in the preview in the log and transfer window, and the identical banding is there in the AIC that is generated in the transcoding.
This makes me think that this could be a bug in the log and transfer window reading the video, and not just an issue with AIC. Does anybody see this issue in FCP 6 log and transfer?
Masud Haq
December 20, 2008 at 8:45 pmI have upgraded to Final Cut Studio 2 and upgraded to the latest versions online (FCP 6.0.5, etc.). I tested all the PH modes (except 1080i60). They all work quite well including the 24p modes.
I am transcoding to Apple ProRes 422. I don’t see any option to transcode to ProRes HQ – can others validate this?
When the clips are transcoded to ProRes 422 through the Log & Transfer window of FCP, my data rate is still not great:
– For 720p60 and 1080p30 I get 17 MB/sec
– For 1080p24 I get about 14MB/sec
– For 720p30 I get about 9MB/sec
– For 720p24 I get about 7MB/secThese clips were all recorded in PH mode so the original data rate for all of the above clips are around 21MB/sec. I am not getting the advantage of these high data rates when transcoded to ProRes. The original AVCHD looks really good when I plug the camera to an HDTV with an HDMI cable, but looking at the transcoded clip on QuickTime, I can see the difference in quality. Particularly disappointing are the data rates for the 24p modes.
Any ideas anyone? Am I not setting something correctly?
Tim Dumont
December 29, 2008 at 2:21 pmMasud,
Hey, I was hoping you might be able to give me some insight as I am about ready to pull all my hair out.. 🙂
I have a MacPro duo 2.66 mhz. I have an internal Seagate 750 GB scratch drive, of which about 350gb is taken already. I also have an external that is not really being used. Regardless, I have had no luck ingesting anything successfully. Can you let me know exactly what your settings were when you ingested your footage? When I try any 1080, even in the lower quality modes FCP crashes. I have tried it off the camera directly and off my hard drive after copying it off the card with the same results. I can see it in the log and transfer window fine and it plays fine there. When I capture it though it plays twice the speed as you reported before.
I am thinking of backing what stuff I need to save and restoring my machine to it’s out of the box state? Any help would be much appreciated.
Tim Dumont
