Activity Forums Apple Final Cut Pro Legacy Here’s a baffler…
  • David Roth weiss
    October 16, 2007 at 4:46 pm
    Thanks everyone for trying to solve this mystery. The spirit of cooperation you have all shown has been great and I appreciate every idea and all input.
    After recapturing, the tapes are proven to be faulty for unknown reasons and I am closing the case once an for all, chalking this up to “asycronous tapes without logical explanation.”
    That is all…
    David
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    POST-PRODUCTION WITHOUT THE USUAL INSANITY™
    A forum host of Creative COW’s Business & Marketing, and Indie Film & Documentary forums.
  • John Heagy
    October 16, 2007 at 4:53 pm
    Not sure if your cameras support this but GenLock is the answer to syncing two or more cameras. You could even use one camera to sync another, or a sync generator feeding both. You might try feeding both cameras a video signal to the input of the camera and see if there’s a “genlock to input video” setting.
    John Heagy
  • Colin Mcquillan
    October 17, 2007 at 6:02 am
    [Rennie] “I was able to figure out which was the bad camera because it’s tapes wouldn’t work in the decks either but as long as I captured from it, it worked. I never understood what was really going on though.
    sounds like the heads are out of alignment on that one camera. I’ve seen it happen to one or two of our ENG cameras (DSR-300a’s) a couple times. The camera that shot the video will playback fine, but not an any other cameras or decks.
    Colin McQuillan
    Vancouver BC
  • Jon Smitherton
    October 20, 2007 at 12:42 am
    I am very surprised that no-one on this forum has ever come across this.
    Strangely enough even identical DV cameras sync will drift after 2 mins or so unless you can lock the cameras to external timecode.
    You could try fitting-to-fill one cam to the other from identifiable sync points – I do this with music vids – abeit a short duration – and works fine.
    You can sync multiple XL2’s via free run and a remote:
    https://dvinfo.net/canonxl2/articles/article11.php
    handy to know.
    The real timesaver is hire a MX50 or a Firewire vision mixer to switch the cams to a deck, and run tapes as iso on the cams, in case the vision mix is dodgy.
    Apparently Capture Magic Pro can record 2 DV streams at the same time, so would be no sync issues.
    https://www.bigmugsoftware.com/capture/
    Good Luck,
    Jon
Page 5 of 5
