Activity › Forums › Apple Final Cut Pro Legacy › HELP with HDCAMSR!!
Aaron Neitz
August 25, 2009 at 12:59 amActually it wasn’t the sync generator – it was the Format Converter on the deck.
The whole time I’ve had a tri-level sync generator.
There’s a sub-sub menu on the SR deck that will slave deck control to the Frame Converter if you have it set to a different frame rate.
Ray Chung
August 25, 2009 at 4:40 amThose decks can be crazy….it’s like choose which city you want to die if you do something wrong. ;-D
