help !! problem with imported powerpoint slides into Vegas
Larry Brewer replied 18 years, 1 month ago 5 Members · 13 Replies
Thomas Roberts
August 10, 2007 at 12:31 amWhat about trying oversample with your footage in Vegas?
TR 16MM -100B with Sony Vegas 7.O and FCP- Have camera will travel…
Neil Moxham
August 10, 2007 at 3:26 amyes I’ll try that.
Althought that will have to be done in the PPT. I believe.
then saved as png, imported.
thanks for all your help, I’ll report back with results
zipedit -
Larry Brewer
August 21, 2008 at 9:01 amZipedit
I’ve used a lot of powerpoint slides in my productions and have tried all the suggestions above and more. The best way I have found to import the slides is to run PowerPoint full screen. Shift/print screen to save to clipboard, then paste and save in PhotoShop to your favorite format. Import these to Vegas and I think you’ll be pleased. Hope this helps.
