Activity Forums AJA Video Systems HDV output workflow question
  • Walter Biscardi
    October 11, 2006 at 5:45 pm
    [Mike Parfit] “We captured in HDV and recompressed when we tried DVCPRO HD. We just didn’t find working in DVCPRO HD that much faster, probably because of the simplicity of our narrative structure.”
    That’s your slowdown. You want to capture native in DVCPro HD through the Kona for the DVCPro HD workflow to work correctly.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Food Network’s “Good Eats”
    HD Editorial for “Assignment Earth”
  • Mike Parfit
    October 11, 2006 at 5:56 pm
    Ah, OK, that makes sense. There must be a difference in the codecs, so the Kona DVCPRO HD codec must work faster in a Kona-FCP system than the one that I create just by using FCP to recompress individual files through Quicktime export.
    But I see that I could use Media Manager to recompress the HDV into the AJA Kona 3 29.97 DVCPro HD codec. Wouldn’t that solve that issue?
    Mike
  • Walter Biscardi
    October 11, 2006 at 6:08 pm
    [Mike Parfit] “Ah, OK, that makes sense. There must be a difference in the codecs, so the Kona DVCPRO HD codec must work faster in a Kona-FCP system than the one that I create just by using FCP to recompress individual files through Quicktime export.
    But I see that I could use Media Manager to recompress the HDV into the AJA Kona 3 29.97 DVCPro HD codec. Wouldn’t that solve that issue?”
    No, the codec is the same, but capturing anything natively to a codec rather than recompressing it to something else always works better.
    Capturing in DV and then upconverting that footage to 8bit SD and then editing with that footage is not as clean as allowing the Kona to capture the DV footage natively at 8bit 720×486 for example.
  • Mike Parfit
    October 11, 2006 at 6:13 pm
    OK, got it. Thanks,
    Mike
  • Kozo Okumura
    October 13, 2006 at 4:39 am
    Walter,
    thank you for your information. but you haven’t answered my question.
    after you finish editing in DVCpro HD codec, how do you output to HDV deck?
    or do you rent or buy DVCpro HD deck just for the sake of outputting?
    Thank you.
  • Jim Tuchschmidt
    October 17, 2006 at 4:07 am
    I too would love to hear if there is an option besides rendering?
    Jim
  • Gary Barr
    July 27, 2007 at 2:53 pm
    has anyone got an answer to this yet? you ingest your HDV to DVCPRO HD, edit your project, then how do you get it back to tape for archiving or whatever? can the guy use the HDV deck?
  • Gary Barr
    July 27, 2007 at 3:01 pm
Page 2 of 2
