Activity Forums Blackmagic Design HDV edit to DigiBeta master?
  • Kristian Lam
    November 30, 2005 at 5:13 am
    [Arwa Merchant] “I made sure that video playback is set to BlackMagic HDTV 25Hz – 10bit (1920×1080).”
    This should be set to “Blackmagic HDTV 25Hz – 8bit” instead as per configured by our Easy Setups.
    Make sure you turn on the down conversion option in the Blackmagic DeckLink Preferences when you’re send the video to a SD deck.
    regards
    Kristian
    Blackmagic Design
Page 2 of 2
