Activity › Forums › Apple Final Cut Pro Legacy › HDMI monitoring from FCP
Michael Gissing
July 13, 2012 at 11:19 pmYour Easy Setup should match the sequence setup. If they don’t then you don’t get moving pics via any I/O card just a still image.
Scott Bihl
July 13, 2012 at 11:24 pmThey ARE matched.
The BMD output setting in FCP is the same as the sequence, but the card is only putting out 1080i 50 to the monitor. It refuses to switch in FCP.Scott
