Activity › Forums › Media 100 › HDe Crashing
  • Andrew Mehta
    April 12, 2007 at 12:13 am
    Well…I was going to suggest installing on a second harddrive, to avoid having to uninstall 11.5, but when I actually hit the link Scott gave you, the page says it’s a Patch Update, and *NOT* a full install.
    In fact it says:
    This is a patch update (non-full install). This update will only update Media 100 11.5
    https://www.support.media100.com/KBSearch/KBDocument.aspx?id=394
    Why not try it and see?
  • Andrew Mehta
    April 12, 2007 at 12:21 am
    Looking at the website again, it looks like you can choose between a full install or a patch:
    Download KB000394 Media 100 11.5.1 Patch Update 11/17/2006
    This is a patch update (non-full install). This update will only update Media 100 11.5. An encryption code purchase is required to run Media 100 11.5. This update is not for Media 100 Producer. A full description of this updat …
    Download KB000396 Media 100 11.5.1 Full Install 11/17/2006
    This is a full install of Media 100 version 11.5.1. This version is an update to Media 100 version 11.5. A Media 100 11.5 encryption code is required to run this update. Please refer to the Media 100 Release Notes document included …
  • Greg Ball
    April 12, 2007 at 6:47 pm
    Thanks…but I’m still hesitant considering I’m working on several projects in my system. I’d love to hear from Scott on this first. I thought he was with Media 100, and suggested a un-install.
    I already have t hard drives , but the second one had FCP on it. so I can’t run use it for media 100
  • Greg Ball
    April 12, 2007 at 6:48 pm
  • Andrew Mehta
    April 12, 2007 at 7:49 pm
    Did you get my other message? Looks like the Media100 support website has both a full install update ( https://www.support.media100.com/KBSearch/kbDocument.aspx?id=396 ), or a patch update ( https://www.support.media100.com/KBSearch/kbDocument.aspx?id=394 ), so the choice is yours. Although fair play to waiting for official word from Scott.
  • Scott_f Media 100
    April 12, 2007 at 8:02 pm
    Hey Greg,
    Sorry for not checking this earlier, we were getting ready for NAB. If you run the Unistall feature from the Media 100 install application it is a very non-distructive process. It will remove the application, items in that folder and some extensions. You do not need to worry about your program/bin/project/ or media files.
    Scott F
    Media 100/Boris Fx
  • Greg Ball
    April 12, 2007 at 8:18 pm
    Scott, but you’re suggesting I do that instead of the patch? Just clarifying.
  • Scott_f Media 100
    April 12, 2007 at 9:18 pm
    You’ll want to update to 11.5.1 you can download it here.
    This patch is a full install of the application so perform the uninstall feature in the installer first before installing this version. Let me know if you have any further crashes after you update to 11.5.1.
    Scott F
    Media 100/Boris Fx
Page 2 of 2
