Activity › Forums › Apple Final Cut Pro Legacy › HDCAM 1080i59.94 Capture
  • Shane Ross
    January 5, 2011 at 9:39 pm
    I see this all the time. QT is nearly always wrong. And j never heard of MediaInfo. Why aren’t you trusting what FCP tells you?
    Shane
  • Andrew Saliga
    January 5, 2011 at 9:45 pm
    Yes, not surprised about QT, but I’ve had several people (specifically on the COW compression forums) suggest not trusting FCP because it’s always wrong and to use MediaInfo.
    Andrew Saliga
    I/O Specialist/Assistant Editor
    Steelehouse Productions
    http://www.steelehouse.com
  • Andrew Saliga
    January 5, 2011 at 10:12 pm
    Making sure I’m following you and it’s not a typo Dave. You say you have encountered that situation?
    Andrew Saliga
  • Andrew Saliga
    January 5, 2011 at 10:45 pm
    No worries. I’ll see what happens. It seems in trying to “fix” this problem I’ve done something that prevents me from editing to tape…
    Thanks for all your help guys.
    Andrew Saliga
  • John Pale
    January 5, 2011 at 11:55 pm
    If you want to fix the metadata, open the clip in Cinema Tools and conform it to 29.97. Nothing will be done to the actual video, since it already is 29.97, but it should fix the metadata.
  • Andrew Saliga
    January 6, 2011 at 4:38 pm
    Thanks John. I’ll give that a shot.
    Andrew Saliga
Page 2 of 2
