Activity › Forums › DVD Authoring › HD to SD Workflow recommendations
David Eaks
July 31, 2012 at 2:37 pm[Michael Slowe] ” Well, I use BitVice”
Thanks, heard of it many times. I’ll have to checkout the trial.
[Michael Slowe] “You predict the death of DVD’s, well they all say this but then it has to be files on drives for distribution, what a pain that will be”
Not so much predicting, as just wishing it, and I mean the death of DVD not Blu-ray. Hoping for Blu-ray to take its place. If (when?) it comes to distribution being “files on drives” (memory cards), the media will probably be the size of your thumbnail (like a micro SD card) and have even more storage space than BD’s. If the price of cards is the same as blank disc’s, I’m all for it. Either that or it all goes to the cloud and streams to the end user, but I think the consumers want to have their “thing on the shelf”. On the other hand, with Netflix, iTunes and download-only games on XBOX/iPhone etc. kids are growing up without the traditional physical media we have always known. Soon they’ll never even know that they are “supposed” to own a disc, everything is just there in their pocket wherever they are.
[Michael Slowe] “Jeff, I think you’ll find you are wrong, DV (SD?) interlaced is also upper field first.”
As Jeff said, you must be working in PAL. Over here it is lower field first for sure.
Michael Sacci
July 31, 2012 at 6:41 pmYeap, every NTSC SD codec is lower field first.
But if/when you are starting with HD (which is upper first) and going out to DVD you want to keep you field upper throughout the process. DVD will play back sd at upper first if that is the way the footage was shot and edited.
All you are doing is keeping the temporal order of the frames constant throughout the process. Compressor will correct swop the flines if you turn on frame control. Episode also does a correct line swapping. Within Fcp you need a swap fields filter. So there are good ways to handle it but you have to know and test what you are doing.
Jeff Pulera
July 31, 2012 at 6:51 pmTo elaborate on Michael’s comments about keeping the field order consistent – this is one of the reasons I switched to CS6 recently. I edit in 1080i and have never been thrilled with the end results on DVD, and have tried numerous workarounds and downconversion workflows.
Encore CS6 now supports UFF for DVDs, so I can edit my 1080i Upper Field First video clips, then export to DVD, keeping UFF throughout the process. Definitely looks better on DVD now. Note that I manually set UFF when creating the MPEG-2 for DVD assets in Adobe Media Encoder. If left to defaults, Adobe will use the standard LFF formatting for DVD.
Jeff Pulera
Safe Harbor Computers -
David Eaks
July 31, 2012 at 11:14 pm[Michael Sacci] “starting with HD (which is upper first) and going out to DVD you want to keep you field upper throughout the process”
[Jeff Pulera] ” I edit in 1080i and have never been thrilled with the end results on DVD, and have tried numerous workarounds and downconversion workflows”
Thanks for this info guy’s. It’s probably the reason I have not been satisfied with the results of any software methods and workarounds that I’ve tried…
Delphine Morris
April 9, 2013 at 10:44 pmHI everyone sorry I jump on this at a later date, reading you and still struggling with the whole HD to dvd workflow. I HAVE to produce a DVD I only have FCP7 and compressor and dvd studio pro and none of the tools and sophisticated roundabout way you mention. How do I get a decent enough looking dvd please! footage shot in 1920 1080i imported in FCP pro res, edited in 1080i timeline, export as is to compressor in QT, dvd settings in compressor as below, then into dvd studio pro and it looks unbearably jagged, interlaced and jittery where I am going wrong please???
Thanks so much deadline looming and panicking here!
dMPEG-2 elementary stream for DVD Authoring
File Extension: m2v
Estimated size: 2.48 GB/hour of source
Type: MPEG-2 video elementary stream
Usage:SD DVD
Video Encoder
Width and Height: Automatic
Selected: 720 x 576
Pixel aspect ratio: PAL CCIR 601 (16:9)
Crop: None
Padding: None
Frame rate: (100% of source)
Frame Controls Automatically selected:
Retiming: (Fast) Nearest Frame
Resize Filter: Linear Filter
Deinterlace Filter: Fast (Line Averaging)
Adaptive Details: On
Antialias: 0
Detail Level: 0
Field Output: Same as Source
Start timecode from source
Aspect ratio: Automatic
Selected 16:9
Field dominance: Automatic
Average bit rate: 5.5 (Mbps)
2 Pass VBR enabled
Maximum bit rate: 7.2 (Mbps)
High quality
Best motion estimation
Closed GOP Size: 1/2 second, Structure: IBBP
DVD Studio Pro meta-data enabledand soun
David Eaks
April 10, 2013 at 1:28 amMichael, I have since been able to get good results with Compressor, see below.
I don’t mean to predict the imminent death of DVD, just wish it.Delphine, the article below gives a good walkthrough for HD to SD in Compressor, the “best of the best’ settings do take a painfully long time, but the second best does a pretty darn good job too.
https://lumenosity.blogspot.com/2010/07/best-apple-compressor-settings-for-dvd.html?m=1
In short:
-export current settings from FCP (not “send to” or QT Conversion)
-import to Compressor & apply Apple DVD preset
-make sure the Format tab matches what your FCP timeline settings were
-change to 2-pass & set bit rate (for longer projects I shoot for 3.8GB estimated size, in the info tab)
-ensure motion estimation is on Best
-enable Frame Controls and set resize, deinterlace & rate to either better or best
-enable adaptive details
-I think thats itDo a short test clip at each quality and call me in the morning 🙂
David Eaks
April 25, 2013 at 1:12 amLarry Jordan recently posted this article- Convert High Definition to Standard Definition Video
Following the article, I just did a short test clip with 1920x1080i from FCPX. Then burned to DVD, tested playback on both a Blu-ray player/HDTV and DVD player/SD CRT TV, I’m quite pleased with the results all around and have some full-length files going now.
Looks like it takes about 2x real time for the downscale, then of course you have to compress mpeg-2 for DVD from the resulting file.
Article’s method in a nutshell-
1) In Compressor, apply the Apple ProRes 422 codec to the HD source. Select the setting.
2) In the Inspector, click the Geometry tab. To convert a 16:9 master file to NTSC 16:9-
Set Crop to Custom and make sure all numeric entries are 0
Set Frame Size to 720 x 480
Set Pixel Aspect to NTSC CCIR 601/DV (16:9)3) Click Submit
Ebond Francisco
July 27, 2013 at 12:02 amThis thread is a year old, but I just found it, and it was EXACTLY what I was looking for. I shoot with Panasonic Lumix G2 DSLR, and import the AVCHD .mts files – I think that’s what they are. I’m very new at this. And I was having an awful time trying to make it look good for DVD. Really appreciate the depth of knowledge from the thread. I’ll have to try some experiments with this. Thanks! ~Bond
E. Bond Francisco
Cascade AV Media Design -
David Eaks
July 27, 2013 at 12:53 amHi EBond,
Just thought I should mention that you should be backing up your memory cards in their entirety. Not just pulling .mts files from the cards and saving individual clips to your computer.
Doing this will ensure you can do proper ingest to whatever NLE you choose. Every file and folder on the card is important, from empty folders to the .mts files. Don’t even go into any folders and look at the file structure or copy single files, leave it alone. Just backup the whole card (backup each card to its own folder and name the folder to identify the content on the card) to your computer and point your NLE to that folder for import.
Ebond Francisco
July 27, 2013 at 2:58 amHappy to say I’m doing that, but thanks for pointing it out! ~Bond
E. Bond Francisco
