Activity › Forums › Adobe Premiere Pro › Has 2.0 changed 1.5 import limitation on drop and non drop frame same time line?
Jacob Rosenberg replied 20 years, 8 months ago 5 Members · 17 Replies
David Cherniack
January 17, 2006 at 5:49 pm[Jacob Rosenberg] “I don’t follow you.”
Hi Jacob,
I can’t gain much from deleting timelines as most are used. It would have been nice of them to put in the function that when you double click on a sub-timeline clip in a timeline that it explodes with the in and out points marked. That way sub-timelines could be easily replaced. Without it it’s a bear to do. Not having that ability and not wanting to ingest 33 hours to replace all my footage I thought I might just export an edl of the finecut and then re-ingest those clips as HD. But the finecut is composed entirely of sub-timelines. And most of those subtimelines have subtimelines in them. If edl export refers only to the sub-timelines in the fine cut and doesn’t recurse down to the original clips I can’t do it.
Why they didn’t include proper media management in this long awaited release is beyond me.
David
AllinOneFilms.com -
Jacob Rosenberg
January 17, 2006 at 5:52 pmYes. Nested sequences will reference source material in their timecode dropness.
jacobhttp://www.premiereprotraining.com
http://www.formikafilms.com
http://www.d2gfilm.com -
Jacob Rosenberg
January 17, 2006 at 5:55 pmI understand. You would want to basically, batch trim individual timelines on a case by case basis to reduce the overall project size and clutter. That’s a great feature.
The media management thing is tough and I can’t really say too much, but suffice to say that there was a lot of rallying and as is typically the case, not enough time. It remains very high on the list.jacob
Marisu Fronc
January 17, 2006 at 6:00 pmJacob-
Just a couple more quick (ish) timecode questions. First, in the 1.5 projects obviously all my NDF code is displayed as DF (or vice versa), when I open these projects in 2.0 is it smart enough to reconvert the timecode back to what it SHOULD be, or will I have to recapture and reedit to get clips with the correct TC. Secondly, will it read DF/NDF over the firewire, or do I need some kind of capture card to get it to recognize both types of code.
slainte,
marisu -
Richard Milner
January 17, 2006 at 6:06 pmI’m sure that Marisu and I will have lots of questions.:)
Jacob Rosenberg
January 17, 2006 at 6:11 pmPremiere Pro natively displays DropFrame, however if the clip was captured DVCAM NonDrop or is Standard Def Non Drop, premiere pro knows that it is Non Drop, but will display the dropframe equivalent. In 2.0 you can turn on a check box so if the clip is Non Drop in a Dropframe project, it always displays NonDrop. If the timecode is NonDrop premiere will tag the file accordingly and you can verify that by looking at it in the project window (now panel).
jacob
if you have an edl you want me to check, you can email it to me and i’d be happy to look at it.http://www.premiereprotraining.com
Jacob Rosenberg
January 17, 2006 at 6:14 pmIf I don’t reply on the cow (I am quite busy right now, but wanted to be active today), you can always email me a question or two and you can find my email on my site: http://www.formikafilms.com
my book(s) and training might answer questions too 😉
jacob
