Activity Forums Compression Techniques H.264 vs x264
  • Craig Seeman
    January 18, 2010 at 8:30 pm
    Have you set Output to QuickTime?
    Once you do that the Video will show as QuickTime Move Settings… and then you have access to your QuickTime codecs. Matrox MAX is accessed the same way.
    Telestream when with Dicas for their encoder. It an MainConcept have been the leaders in supporting H.264. There are quite a bit of differences between the codecs (It’s what makes H.264 unusual compared to other codecs) some of them involve what features of the H.264 spec are accessible to the developer and end user.
    You might want to read the excellent article by Jan Ozer of StreamingMedia on the subject.
    The article is a bit long in the tooth now as Dicas has made major improvements in their codec.
    So Many H.264 Codecs, So Little Time
    https://www.streamingmedia.com/article.asp?id=10570
  • Brent Streeper
    January 19, 2010 at 1:56 am
    Thanks Craig!
Page 2 of 2
